- Dec 27, 2008
Installed a SILVERSTONE FHP-141 140mmx38mm fan on one end of my Coolermaster Nepton 280L AIO and knocked off 3c from idle temps and 7c from max load temps! Amazing! I wish there were clearance on the other end of the radiator for another one but there isn't. Got a Yate Loon 140x25 on the way, however which should do better than what's there now which is a Delta 120x25mm high speed fan. The Delta moves a lot of air but doesn't completely cover the 140mm wide radiator.
The SILVERSTONE FHP-141 is simply an amazing fan! Huge static pressure increase over the stock 25mm thick fan and you can really feel the difference in the volume of air coming out the top of the rad. The Silverstone is also quieter than the stock fan at full throttle and you can turn it down to almost nothing with a fan controller before it stalls. Really low impedence.
