Hello,
I need a new system and its been awhile since i built one. I really dont know what components are good these days. I thought maybe you could help.
Uses: mild gaming and photo/video editing. Nothing extreme gaming wise... But will need ram for photography
Would like to reuse these parts from current computer:
2 250gb solid state raid
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148443
Corsair HX750 power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
Nvidia gtx 550
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130604
What i need:
Amd chip
Amd motherboard
Ram 16gb
Case
Budget $600
Here is my intial thoughts
Case - antek black steal mid tower atx
Mb- asrock fatality 990fx am3+
Chip - amd fx 6300
Memory - gskil ripjaw x series 1600
any thoughts? Will i be able to use the old parts listed above? Thanks in advance.
-JC
Nvidia gtx 550
What i need:
Amd chip
Amd motherboard
Ram 16gb
Case
Budget $600
Chip - amd fx 6300
-JC
