Yup! You guessed it!Moto7451 said:Is the aqua color because you're chilly now?
Oops. I forgot to update that. . . . It's actually 22C load, -9C idle. . . And the pelt allowed for a 500MHz higher overclock. . . I agree, that's not a phenomenal increase in performance. But at this point, I'm not really sure if the cooling system is to blame. . . I'll be picking up a DFI Expert pretty soon and I'd like to see if that board opens up some more potential. . .Pirate_Freder said:...so basically the pelt is making no diff in your system? at least nothing worht it, 28C when at a decent oc...that certainly doens't osund like it's worht all the work and the extra couple hundred dollars
I know it seems weird. But remember, I have my system setup so that it automatically underclocks and undervolts when it's idle. That's how I get down as low as -9C. I like it this way because when I'm sitting reading through a thread, writing a post, or doing anything that's not CPU instensive, I don't need to be overclocking. However, when I do have a load on the system, it automatically overclocks and overvolts. (I use a great program called RightMark Clock Utility to do that. It works like Cool n' Quiet only much better.) . . .Pirate_Freder said:yeah that's not too bad actualy, congrats man, i don't llike that temp range though -9 to 22 wtf?!? that's a huge diff
I guess I really should mention a comparison of the temps when running idle and load at the same speed and Vcore.Revivalist said:-9C at idle (underclocked to 1.06GHz and undervolted to 1.07V)
22C at full load for 20 min (overclocked to 2.60GHz and overvolted to 1.70V)
Actually, it is staying below ambient (which is 25C in here), even when it's overclocked, overvolted, and under a load for 30min. . .Pirate_Freder said:...water cooling can get those load temps though, because the limit of water is ambient, this doesn't make any sense , is it maybe that you don't have enough cooling power to cool the hot side of the tec? say if you were able to hit ambient on the hot side of hte tec wouldn't it then do subzero with ease? (since diff between hot/cold side on these tecs is about 59C)
Revivalist said:I was thinking about finding some kind of variable resistor to put in series with the TEC to drop some of the the voltage and see if it gets better temps. . . . Anyone know what I could use?
LOL no problem!!!Revivalist said:Ok, I was able to tweak things a bit and keep load temps at 20C. When I left the system overclocked/overvolted, it settled at 2C. . . So it's about a 18C range, just just as Joe Camel predicted. . . .
By the way, thanks Joe for all the preliminary info way back at the begining of this whole project. I finally did it . . . I entered the world of "extreme" cooling. . . .
But somehow I have a bad feeling about where this road leads.
