- Mar 27, 2005
- Fresno, CA
Ok, I almost got all the parts I'll be using for a pelt setup. They are . . .
• Maze4-1 CPU waterblock: (Dangerden )
• Insulation material: Neoprene, conformal coating, and dielectric grease (dangerden)
• 320W (50mmx50mm) Peltier: (15V max, 26A max) (ebay)
• Meanwell 480-15: (trcelectronics)
• Power relay: (bestbyteinc)
My question is what kind of safety precautions can I set up to avoid any disasters including the destruction of hardware or, even worse, a fire? (I just read this thread from Xtreme Systems and I got a little concerned.) So far I already have the following for safety . . .
1. A relay so that the Meanwell (powering the pelt) always turns off when the ATX power supply off. This protects me from accidentlly leaving the pelt on.
2. A program called "Shut-down" which works with Motherboard Monitor to shut the system down if the CPU temperature reaches a certain temperature (which I was going to set to 50C)
Is there anything else I could implement? I was thinking that there is no protection for the following possible problems . . .
1. The relay fails to turn off the pelt when the system is shut down. (This would be really bad if I leave the house right after turning my computer off.)
2. The program "Shut-down" fails to work when the temperature reaches 50C. (I think AMDs have a built-in thermal shut down but I don't know.)
