- Mar 27, 2005
- Fresno, CA
- Thread Starter
- #61
Well, I don't think you would reach that kind of heat with just a CPU and a TEC. For example, my CPU pumps out about 135W when overclocked. The TEC being run at 12.3V is adding about 165W. So that's about 300W together. The pump is throwing in another 24W as well. But my BIX III, mcp655, and 1/2 tubing seem to be taking care of the job pretty well. Unfortunately, it would be difficult to do an exact calculation of how much a water loop could dissipate. There's just too many factors (such as flow rate, ambient temp, radiator dissipation rating, etc.) Did you check out this guide yet? Notice in the end the author mentions that you pretty much have to just get a general idea of how well a water loop will perform based on the experience of others, and of course your own as you experiment.Pirate_Freder said:oh lol my bad i meant an outPUT . so yeah how much wattage of dissapation in the rads does it take to hit ambient with about 400w coming out of the hot side of the tec?
Honestly, I'm not really sure. I hear the term used all the time and I think it has to do with a CPU not being able to boot when it's too cold, but I don't really know for sure. Probably someone with a phase change system will come along and enlighten us.Pirate_Freder said:LOL EDIT AGAIN- just saw another thing, what's up with this whole cold bug thing? i've heard mentio of it before. what is it? comp doesn't work cause it's too cold?
