Welcome to the forum awesomejlee...
...It is "now" understood that AMD cpu temps while not under a load are mostly useless. About the only time an idle and not loaded temp on AMD FX processor would be of any value is if HWMonitor Free version should show and idle temp of 45 or 50c which would indicate a p00r contact between top of cpu and the cooler when looking at the Package/Core temp in HWMonitor Free version for FX processors.
You notice I mentioned HWMonitor Free about twice already and that is because that is what we use in trying to help users in these AMD cpu and mobo sections. What you use 'after' you get your help is up to you but we try and stay on the same page while trying to help. Thank you.
This is what we need to see for sure and a real good starting point.
Normally during setup and testing we disable C1/E, C6, Cool N Quiet, APM, TurboCore and in windows performance manager itself we set to "performance" mode. ALSO if you have HPC in bios you would ENABLE it. That way there are not "other" settings messing with the overclocking process. Some of those settings are not available on all models of cpu but where in evidence we disable for setup of overclock process.
CPU Tab in CPUz from CPUID com
Memory Tab in CPUz from CPUID com
SPD Tab in CPUz from CPUID com
And this is screen capture of HWMonitor (free version) from CPUID com
HWMonitor has been scrolled enough and large enough to show Min/Max of Voltages and includes the CPU CORE TEMPS / "package" temps fully visible. Latest versions of HWMonitor show the CPU Core Temp as " a Package Temp" and is only shown as a single temp since there were never multple, individual core temp sensors anyway.
This capture is made of HWMonitor after it has been open and running on the desktop logging Min/Max temps and voltages while Prime 95 was running Blend Mode test on all cores for at least 20 mins and then the capture of HWMonitor was made and it shows the Min/Max temps and voltages before P95 Blend was started and while running P95 Blend mode and gives much greater insight into how the system is performing without guessing.
In order to attach screenshots of INDIVIDUAL images as suggested, first crop and capture the images with Snipping Tool found in Windows Accessories or equivalent. Then click on Go Advanced, a button at the bottom of every new post window. Then click on the little paperclip tool at the top of the Advanced post window when it opens. Clicking on the paperclip tool brings up the file browser/upload tool and the rest is fairly obvious.
We have people that cannot see and thus help when images are 'linked' and not attached direct to the forum. And FYI thing.
RGone...
EDIT:
If you feel you are ready to rock and roll and got it covered...then please go back into your first post of this thread and before the current title > add [RESOLVED] that way others will not be concerned and also looking with forum search others can search [RESOLVED] for your type thread and get to answers far easier.
Again thanks.
END EDIT.
