his is my first post at this site, so hello to all. I'll also say I've never really messed seriously with over clocking my CPU before so a lot of this is new to me.
CPU: AMD 64x2 Manchester 4200+ @ 2.21 Ghz
Motherboard: MSI K8N Neo4 Series (MS-7125)
RAM: 2x SuperTalent SUPERTALENT 1 GB PC3200 DDR SDRAM
Video: ATI Radeon x1950 pro 256 MB
Power: OCZ 420W Powerstream
OS: Vista 32 SP1
Othersoftware: Everest, SuperPI and Prime95 2.58
The computer has an after market cooling solution. I'm not sure what it is since I bought the original computer 2nd hand, but its a really large heat sink with a large fan mounted on the side of the heat sink (so that the fan is facing the bottom of the case), anyways...
As of now, I have it stable the system stable at 20% OC which is FSB 240 Mhz, HT 4x, CPU Voltage @ +3.3% 1.446 with the ram at 166 Mhz.
Idle:
CPU 38 °C
CPU #1 / Core #1 37 °C
CPU #1 / Core #2 39 °C
Load (10mins of Prime95 Torture):
CPU 52 °C
CPU #1 / Core #1 54 °C
CPU #1 / Core #2 60 °C
I'm trying to hit a stable FSB of 240 MHZ. I read the stick on A64s which I was read else where doesn't necessarily transfer to the X2s. So I have a few questions:
a) What idle and load temperatures are "safe"?
c) Do I need to be concerned with all CPU temps ie CPU, CPU Core #1 and CPU Core #2?
c) How long do I have to stress the CPU before I get an accurate load temp.
d) What type of FSB should I be aiming for with this type of CPU?
OS: Vista 32 SP1
Idle:
CPU 38 °C
CPU 52 °C
