Hi all, so I havent done any water cooling before, but I have built my own computer's for the last 6-7 years or so. I have finally decided to take the step and build a very nice PC and make it liquid cooled. I just have some questions on parts etc etc. I will link my graphics cards and my cpu below so you all can see which ones im using, I will only be water cooling those components.
GPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16814487002
CPU http://www.newegg.com/Product/Product.aspx?Item=N82E16819116940
Now below I will link the parts I think I should get (again no experience) so please help me if you see something that is wrong. All components will be from Frozencpu.com
Liquid - Distilled water + .99 pure silver
Connections x7 - http://www.frozencpu.com/products/2..._19mm_OD_12_x_34_-_Black.html?tl=g30c409s1609
Connections x6 - http://www.frozencpu.com/products/2...ion_Fitting_-_Deep_Black.html?tl=g30c409s1611
Pump - http://www.frozencpu.com/products/1..._Pump_-_Black_MCP35X2-BK.html?tl=g30c107s1598
Radiator x2 - http://www.frozencpu.com/products/1...Profile_Split_Fin_Radiator.html?tl=g30c95s160
Reservoir - http://www.frozencpu.com/products/1...-_Clear_-_Revision_2_15033.html?tl=g30c97s168
Tubing - http://www.frozencpu.com/products/1...4_OD_-_Laboratory_Tubing.html?tl=g30c457s1151
CPU Block - http://www.frozencpu.com/products/1...emacy_Elite_-_Intel_2011.html?tl=g30c325s1572
GPU Block - http://www.frozencpu.com/products/2..._Ti_-_AcetalNickel.html?tl=g30c311s1996#blank
The case im using is http://www.caselabs-store.com/mercury-s8/
Again I am brand new to this and I know im missing some things. If yall could be so kind to help me out and let me know about the parts ive picked, etc! Thanks so much!!
