- Dec 28, 2009
- Thread Starter
- #21
Darkpyro:
When you say I need plenty of good airflow, is that because you're figuring the franken-radiator and the shade-tree-reservoir will be in the case? 'Cause that will not be happening. I know I'll probably have to add a bit more tube, but I'll be going outside with the homemade crap. Only trustworthy parts on the inside. Things with superglue or JB stay outside. Besides, if I do the radiator the way I'm thinking I will, it'll be around 30" tall!
BTW, I'm returning the store-bought stuff today. I'm thinking that, since I'll be getting the 655 now, I can rig up either the 1/2" copper or even dig out some 3/4" and build the radiator onto the reservoir so pressure won't be as adversely affected. Also, I'm going to get some aluminum flashing to make fins (I KNOW, don't mix metals INSIDE the loop). This will be all outside of the loop, outside of the case, and hopefully not given to condensation.
"What about that fog on the window?" "That is not fog, John. It, too, is condensation."
