- Oct 6, 2004
- Oklahoma City, Ok
One quick suggestion that I think Cathar originally made....
Try out the 7/16" ID 5/8" OD Masterkleer tubing from www.mcmaster.com
It fits snugly over 1/2" OD fittings (its a little work but nice fit), has a really nice bend radius without kinking, due to its flexibility its easier to work with inside a case than the 1/2" ID 3/4" OD tubing I have tried and it runs right about $13 delivered in the US. Thats 25 feet of tubing which allows you more than enough tubing for multiple systems. At $0.37 a foot its pretty much a steal by comparision to the Clearflex or the higher end tubing available.
