- Jun 13, 2005
- Thread Starter
- #61
Bump! Will be adding pics here soon.
capneedle said:Your shroud design is very similar to mine. I like the use of fiberglass as well because of the ease of moldability and the quickness there is with it. See the link in my sig to see my shroud and scoop design via fiberglass.
goodolarchie said:[Kneels before hologram] It is your bidding, my master.
Anyway, it'd be nice if I had problems with the tubing, because that would mean I had a case to begin fitting it into
Mostly I was just unimpressed with its flexibility vs. the normal vinyl tubing I'm used to. I'd heard about the hot water trick, I'm sure it works wonders for the PVC. Will steaming hot water >> bathtub not work well though? Seems easier than tongues, fitting tubing into a pot, etc. Hopefully this trick will prove useful in the next.. say couple weeks.
capneedle said:I used 5/8" OD barbs for all of my 1/2" ID tubing. This was done to avoid any flow restrictions as the ID of the barbs was then 1/2". Worked beautifully, but needed to do the boiling water trick. I just boiled the ends and slipped them on. Boiling tubing does work very well and highly recommended. You don't have to get it super hot, just enough so it's more moldable.
crash013 said:Very ghetto indeed
pwnt by pat said:Looking good so far. It's nice to see someone making a fg shroud.
Anyway, my suggestion:
Put another thick layer of resin on top of the fiberglass. It looks like you used no where NEAR enough resin on the whole thing. The shroud needs to be completely soaked with resin - basically looking like the inside of the shroud. Also, to cut down on the amount of resin you use, (liquid I assume) add flour or sawdust to the mix. It will make the resin nice and thick.
Also, when you paint, black will show you a LOT more than white will. Trust me on this one. Make sure you bondo and sand. Drywall sanding spongues help alot. You can get them really cheap at Home Depot and they have 60 grit on one side and 100 on the other. They are AMAZING for sanding curved bondo surfaces.
Finally, to greatly improve the pretty-ness of the shroud, cut the sides off until they are all flat and even. Obviously, this will get rid of that butt ugly curl.
