1Moreusername
- Jul 15, 2018
Greetings!
Some background: I haven't built a computer in about 15 years (never water cooled) and decided to be super ambitious and build a loop using hard tubing and EK HDC 16mm G1/4 fittings. Everything went great (so I thought) after the learning curve with bending and my first loop was completed 2 days ago and set for a 24-hour leak test. At the end I had no leaks, but I could see some cracks forming about 2-3cm from one of my fittings. Turns out in my haste to finish the loop I think I applied a little extra force to get the tube to meet the fitting exactly and at some point the tube cracked. Yes, I know that was a stupid thing to do. Lesson learned. No more applying extra force. If it doesn't work, rebend it. However, I thought it best to disassemble the loop and do it properly. This results in several questions I'm hoping someone can help with:
1. I used some 90 degree revolving fittings: These have some give at the joint where the fitting is made to rotate, obviously there was some stress on my loop resulting in the above problem. How much force can those joints take before I risk having damaged them and should just replace them? I have no idea how they're made or constructed inside otherwise I'd have a better idea.
2. Tightening some of my fittings resulted in some shavings where I assume it was some of the inside painted surface of the fittings coming off or residual metal from the threads coming off. Am I wrong and is this a sign I damaged the fittings when tightening? I see no other indication that that is the case.
3. O-rings: I can't see any visible damage to the o-rings on the fittings but I'm considering replacing them prior to the re-install. However I can't find anywhere to get them despite multiple google and reddit searches (I'd prefer not to purchase directly from EK due to shipping costs and time). Any suggestions?
4. There are some shavings that made their way into my video card block despite having rinsed out all components prior to building the loop. Is it absolutely necessary to break down the water block and remove them? One I was able to get out with rinsing, the other is a small piece pinned against the side where the water runs over the GPU. It doesn't look like it is having much effect on flow across the GPU.
Thanks for any help you can provide!
