Hey guys and gals, the setup for my 2nd rig is listed in my signature. For a few months now, instead of running my 2500+ system at:
([email protected])@1.675Vcore in BIOS, I've been running it at:
([email protected])@1.525Vcore in BIOS with 1 stick of 512MB PC3200 Corsair XMS and timings of 8-3-3-2 @ 2.6V. It has been very stable.
I had another stick of 512MB PC3200 Corsair XMS memory in a different system, so I swapped it out and added it to this computer. My computer POSTS but wouldn't boot into Windows. I had to up my timings from 8-3-3-2 to 8/11-3-3-2.5 and currently have my FSB lowered from 215 to 200. Otherwise, Windows doesn't boot, or if I did, once I get to Windows, there's random reboots/freezes only a few minutes into the desktop.
EDIT: Now I just found out I need to lower my CPU multiplier from 10 to 9.5, or else Prime95 gives me an error during its test after only a few minutes. DoH!!!
Is there any known issues with having to run losened timings or lower FSB if I am running dual channel? Or could it just be that the 2nd memory stick can't handle as much?
On a separate note: Although the manual says to use DIMM3 slot first in that order, which is what I had before on single DIMM mode. But when I used dual channel, it won't even POST if I used DIMM3 slot. I had to switch the memory to DIMM1 and DIMM2 slots.
Thanks in advance!
Thanks in advance!
