- Jun 21, 2004
enduro i believe with all of the new modded biopses the d10 sata corruption has been fixed
now if they can only fix cpc..
Bassmankr said:Sen, I thought the common forum thinking was that if you had double sided BH-5 in a 2 - 512 (1 gig) package ala Kingston Hyper X that the CPC off bioses were the ones working best. Also I thought that if you were running SATA raid you should stay clear of the D10's and go with the later bios'es because of file corruption. Can someone clear this up? I'm not doing too bad with Trat's D24 CPC off with a medium speed panaflow for cooling (its a music box so I have to limit noise and therefore I'm heat limited on the CPU), and should try the D25's soon but if you guys think the D10's won't corrupt my SATA raid I may give them a spin.
Sentential said:Im 100% positive. Ive gone thru all the BIOS, and I think people will agree. If you are OCing an NF7 you fall under 2 catagoies depending on your RAM.
Nonstandard: Winbond varients BH5,CH5,BH6. Micron, and low latency RAM in general
Industry Standard: Hynix, Infineon, Samsung, Elipidia, Adata, Generic. High latency RAM
If you are using non-standard RAM, use a D10 varient with CPC on, *not off*. Non-standard RAM does horribly with CPC off.
However if you are using Industy-standard RAM, use D2x series. Standard RAM does horribly with D10. Also, use a CPC off BIOS for high speed RAM, it yeilds fantastic results.
Best BIOS:
For BH5, CH5, BH6, and mT -5BC (OCZ's EB) the very best BIOS is either: Tictac's D10 Beta4 Turbo, or Tictac's D10 Beta 4x4 Turbo.
For Samsung TCCC / TCCD and Hynix BTD43 / D50 varients. The very best BIOS is Trat's D24 with CPC off. Honerable mentions include Tictac's D23 Sub-Zer0, 3Dfire, and D22 Alpha1 Betaking Turbo.
Didn't work for me either... try it a couple of times.NaNoBLaZe01 said:link doesnt seem to work for me =\
Like many people I am running a summer overclock right now at 2.7GHz (2.1v).Tebore said:Hey Nico I saw in your sig that you have an AXP-M at 2.8ghz, what are you using to cool it at 2.2volts? And man would I love to see some Sandra CPU benchmarks, that would really show up my friend who says Athlons are slow compared to his Shiny new P4.
[/end highjack]
