- Jul 25, 2004
- Sylva, NC
so jw, cpc good or cpc bad?
Joor said:D24 /25 is fine 225 max tho, this is 2x512 pc4000
They both run 250 fsb if single..dont get this?
100mbHD said:jess, in your sig, the NF7, what mem timings are you running on that board? thanks
100mbHD said:wow, nice, i can get up to 255fsb with mem timings of 3-4-4-11 in DC w/ my hynix chips. also, what is your cooling on your NF7, because I noticed that your running it at 1.9 vcore, which is a lot.... and if possible, your vdimm and chipset voltage, thanks.
Archangel4life said:nano you should try the d10, im at 3700+ in sandra mem wise.
@ 230 i was at 3500+
JPetrillo said:What would you guys recommend for me? (which BIOS)
This is what I'm setting up tomorrow, I would like to flash the BIOS 1st thing before installing Windows. As of right now I'm going to try the D10 Beta 4. If I'm not happy with that I'm going to try the D25 - or would you all recommend something different than that idea?
ABIT NF7-S nForce2 (Model# NF7-S V2)
OCZ Enhanced Bandwidth Series Platinum Edition 184-Pin 1GB(512MBx2) DDR PC-3500
AMD XP 2600+ Mobile
There are so many to choose from! What bioses would you try out with that system^
