- Jul 1, 2009
AMD ATHLON XP 3000+ (SYSTEM CRASHES AT NORMAL SPEED)
Here is my problem (I hope someone can help):
I recently installed an AMD Athlon XP 3000+ (2X200MHz) in my ASUS A7N8X-X mobo. Everything runs just fine under normal conditions. However, when I launch certain games, the system crashes after about 10-15 mins. Other high-demand games run just fine (it actually seems that the lower CPU intensive games have the problems).
I have noticed that if I back the clock speed down to about 175MHz (or less), everything runs great (if a little slow). I believe this is because that is the speed at which the memory defaults to "tighter" timings (i.e. - 3-4-4-7). The RAM that I have installed is kind of cheap (it only supports memory timings of 3-3-3-8 @ 200MHz w/ 1:1 FSB-DRAM ratio).
I have done exhaustive web research on this issue and have run numerous diagnostics to ensure that all of my hardware is performing properly (i.e. - OCCT (CPU, GPU & PSU "stress" tests), memtest, etc.). I have also installed SpeeFan (temperature/voltage monitor) to make sure that everything is running in line with tech. specs. Everything looks good and I have found no obvious errors.
-So, my question for the "experts" is this:
*WILL UPGRADING TO HIGH-PERFOMANCE RAM WITH 'TIGHTER" MEMORY TIMINGS (i.e. - 3-3-3-6 (or better)) FIX THIS PROBLEM?*
I have tried everything that I can think of in an attempt to pin down the cause of this instability issue . . . all to no avail! I have exhausted every possible solution that I can come up with and have not been able to fix the problem - I NEED HELP! I am just hoping that someone with some experience and expertise in these matters will read this post and be able to offer some sound suggestions (I am willing to try anything that might work at this point). I just want a decent gaming system that works properly; I can't afford a new one right now.
-Below are my system specifics:
ASUS A7N8X-X ACPI BIOS Rev. 1011
AUSTIN 450W PSU (DR-B450E)
*PC3200 DDR 400 RAM (1.5GB)*
ATI Radeon X1650 Pro AGP (256MB)
WDC WD800JB-00JJA0 (HDD0)
ST380215A (HDD1)
LITE-ON DVDRW SHW - 160P6S (not used for gaming)
NVIDIA nForce2 400 Chipset
I am running Windows XP Pro and have all latest BIOS (Pheonix - Award) & Driver updates (I think)
*** Also, it is important to note that this system was running well with my previous AMD Athlon XP 2400+ CPU (if a bit slower) *** (all these same games were playable before) ***
-Let me know if you have any further questions or need more information to assess the problem.
-THANK YOU FOR TAKING THE TIME TO READ THIS POST - ANY SUGGESTIONS OR SOLUTIONS ARE GREATLY APPRECIATED!-
ST380215A (HDD1)
