Noctual NH-D14 come with 1 120mm and 1 140mm fan. It is possible to run 2 140mm fan? I want to replace the 120mm fan with a new fan that is 140mm and is 2000prm. Or any recommandation for 120mm and 140mm with 2000rpm capable fan.
However, if you use the Samsung ultra-low-profile RAM you could use a front 140mm fan, if your case will allow it. As noted above, a front 140mm fan will only get you 1-2c better cooling, but it will be quieter than a 120mm fan.
