Yep, 1-4 splitter. I do have the packaging. It arrived last week, and I'm waiting for my video card RMA to start building the case and other goodies.
You can get 7 fans that way...one of the fan plugs on the splitter cable reports RPM back to the motherboard header (yellow wire is hooked up only on one plug). You cannot mix two fans together on that one wire or your motherboard will have an impossible time of regulating speeds.
See, a fan sends two "blips" per revolution to the motherboard via the yellow wire, that's how the motherboard knows how fast the fan is moving.
If you hook two fans to that connector that's sending that signal, the motherboard gets 4 blips per two fan's single RPM, and two fans are usually slightly out of sync, so it gets confused as to the real RPM and can't give a good power modulation signal back to the fans. The fans start revving up and down, and sometimes will even stop randomly.
Don't go there. You won't like it.
The one plug that uses the yellow wire MUST be a single fan for the whole thing to regulate correctly.
Sorry!
