So here is a look at my build
just planning out where my tubes will run
here is a list my parts
Cpu block - EK-Supremacy EVO(copper)
Radiator -Alphacool NexXxoS XT45 Full Copper X-Flow 360mm
Fans- Noctua ippc 3000rpm
Pump - LAING D5 STRONG 8-24V Pump (MCP655-B, PMP-450S & Other Re-Brands)
Pump top - Bitspower D5 MOD TOP (Clear "S" Model)
Reservoir - Alphacool Phobya Balancer 250 black matte
Tubing - Mayheims non(uv) Ultra Clear Tubing (1/2 - 3/4) 13/19mm Tubing
Fittings - (6) F1 Racing G1/4" Thread Dual Rotary 45 Degree Compression Fitting for 1/2" ID - 3/4" OD (13-19mm)
(2) Koolance 90-degree Swivel Angled for 13mm x 19mm (1/2in x 3/4in) *Black*
(1) Bitspower 1/2"ID - 3/4"OD Straight Compression Fitting - Matt Black
(1) Bitspower 10mm Dual Connecting Spacer Adapter Male/Male - Chrome
(1) Bitspower 50mm Spacer Adapter Male/Female - Silver
(1) EK-AF Extender 20mm M-M G1/4 - Black
(1) Darkside Ball Shutoff Mini-Valve - Black
Cpu - i7 6800k
Mobo - Msi x99 gaming carbon pro
Gpu - Msi gtx 1070 seahawk ek
Ram - G skills ripjaw 32gb pc19200
Psu - Corsair (gold) hx1050
Fan controller - Aerocool 2100 touchscreen
Case - Cooler Master Haf x
Tell me what you guys think
