OP P pigeonfood Registered Joined Nov 17, 2011 Nov 18, 2011 Thread Starter #21 do i have to use this bios utilty or can i use something else to alter cpu settings?
W wingman99 Member Joined Dec 10, 2003 Nov 19, 2011 #22 You have to use Bios turbo settings and you can go 4 bins over stock turbo and that will be 4.2GHz, with one core and 3.9GHz with 4 cores. You can use the stock cooler it will work fine to keep it under 80c Attachments limitedunlock_sm.jpg 78.1 KB · Views: 199
OP P pigeonfood Registered Joined Nov 17, 2011 Nov 19, 2011 Thread Starter #23 I dont understand....i cant use my bios settings at all, this picture a program?
OP P pigeonfood Registered Joined Nov 17, 2011 Nov 19, 2011 Thread Starter #24 i press delete and the efi bios utility comes up...but there is nothing in that to where i can alter settings!!
Crimson Registered Joined Nov 6, 2011 Nov 19, 2011 #25 Dude, why you didn't bought the K-Version If you planned to do overclocking..
bmwbaxter Member Joined Jun 9, 2010 Nov 19, 2011 #26 pigeonfood said: i press delete and the efi bios utility comes up...but there is nothing in that to where i can alter settings!! Click to expand... There should be a tab that you can click in the top right corner which will allow you to go to the advanced setup where you can adjust settings.
