Is my e6600 running at 3.2ghz or 3.6ghz?
Here Are My Specs:
Asus P5B-Deluxe
Intel Core Duo e6600 L631A
eVGA 7600GT KO 256MB
2 x 1GB Crucial Ballistix DDR2-1000
Samsung 18X DVDRW Combo
Thermaltake Armor Balck Tower case w/ 25 cm Fan
OCZ GameXtreme 600W PSU
Is it normal for the 25 cm fan to be touching the top of my Tuniq Tower?
What setting would you recommend me to OC at?
What programs are most reliable for Vcore and Temp readings?
What programs should I use to test stability?
I hope to run at around 3ghz daily and maybe 3.6ghz every once in a while. Are there problems with my temps that would prevent this?
What is a good vCore for 24/7 use on an e6600?
Please give me some answers and suggestions.
Here Are My Specs:
Asus P5B-Deluxe
