OK i decided to drop the CPU voltage to the next lower level in the BIOS.
And then i run the same test (Prime95, 20 minutes) and the results are seen below.
Better right? I think i will continue to lower the voltage step by step and then test. What could go wrong this way for my system ??
And I still think you need to redo the TIM and reseat the cooler. Until you can lower those core temps you have little or no headroom to overclock any further.
You mean that there is more room for improvement than what I have achieve d and I immediately need to do the reseat process ?
Yesterday you said you were going to add a top fan. Instead, you added a more powerful rear fan. What changed your mind about the top fan?
Someone earlier on it this thread suggested taking the side panel off of your case and running a stress test? Did you try that? If you do that and temps improve significantly then that tells you case ventilation is inadequate. Please try that.
Also, I had asked you earlier what was the make and model of your case and you never responded. We are here to help you but you need to work with us.
Also, please create a "Sig" so that your system information travels with every post you make and people trying to help you have ready reference to it. You can refer to mine if you want an example of what we like to see in a Sig. To create one, just click on Settings (top left corner of screen) and then click on Edit Profile about midway down on the left side.
What is the room temperature where this computer lives? High ambient temps contribute to high machine temps. We frequently see this with forum members who live in hot places w/o AC.
I bought the new fan (120 x 120 x 25, 1200 RPM) initially to add it to the top of the case but i noticed that it was obstructed by the cooler and the memories. So i decided that since it had more RPM's to replace the old fan (120 x 120 x 25, 700 RPM) that came with the case with the new one. So i did that.
I'll test that also.
The case is the Thermaltake Commander MS-I vn400a1w2n middle tower.
I'll do that OK.
32-33 max celsius degrees these days
Okay, that explains some things. That is HOT! That's 10c hotter than my room temperature. Where do you live?
In looking up the specs for that case, I see you have the ability to install a front fan. I would consider putting in a stout fan in the front. If the push fan in the front of a case moves more air that those in the top and rear that are exhausting then that helps keep dust accumulation down.
