Summarising the last few posts and the changes i need to make in order to proceed now.
1 ) I need to change Command Rate to 1T. Is this the one called "1T/2T Command Timing" in the picture below ??
2 ) I need to change CPU/NB voltage to 1.25 . Is this the one called "NB Voltage Control" in the picture below ?? I noticed that when i change that value to 1.25 the color of the value becomes red as a sign of not normal voltage i guess. Is it OK with that ??
- - - Updated - - -
Is that the "Set Memory Clock" setting in my BIOS ?? Do i need to change that along with all the other changes from the post above ??
The one change that is straightforward is the change of CPU VCore Voltage to 1.325V. I have already changed that.
One last thing. Now that we are going in Overclocking mode is there any other settings like "Cool n Quiet" or "C1E Support" that i need to disable ??
