adamgloster
- Dec 20, 2014
first let me list my specs to my pc then i will explain the problem
cpu 3.90 gigahertz AMD A8-6600K APU with Radeon HD Graphics
motherboard gigabyte F2A88X-D3H
8 gig of ram corsair vengance 1800mhz ddr3
430 watt corsair psu
coolermaster evo heatsink
120 gig kingston ssd
windows 7 ultimate 64 bit
So I am trying to over clock my CPU with amd overdrive, at the moment i have turbo mode on and the CPU is running permanently at 4.2 ghz. When i overclock the cpu to 4.3 or any higher the highest i have gone is 4.5ghz when i run the stability tests it passes fine, and when i use my pc then for gaming or web browsing it is fine but were i run into a problem is if i try to watch a you tube video. It just stutters all over the place and it is just unwatchable the same goes for if i put a dvd on to play it will not play it runs slow and again stutters. I am new to over clocking and really hope some 1 can help me just for information i have not changed any thing in my bios before over clocking hope some 1 can help many thanks adam.
