The log is a bit small to read real clearly, but three problems:
1) Ask before connecting Yes, should be No
2) Use IE connection settings Yes, should also be No.
You'll be unable to get another WU with #2 set up as yes.
Stop the client, and either start them with the -config option flag, or delete the client.cfg file, and when you restart the client, it will see that you don't have a client.cfg file, and be kicked into setup mode to make a new one.
Do you really want the client to STOP and wait for your OK before connecting to Stanford? I'd lose hours and hours of folding if I did that.
3) Using standard loops.
Previous termination was improper.
Standard loops are horribly slow. Stop the client ONLY by clicking on the client's window and then pressing Ctrl-c down (if it's a foreground program), or using the service manager, if it's installed as a service. (Right click on the service, and choose Stop from the pull down list).
It will help if you add the start up option flag -forceasm to the FAH client. If you need help with that, let us know.
