Today I went to frys with my friend to shop for a new rig. The specification are as below:
Gigabyte EP45-U3P rev 1.6 motherboard
Q9550 E0 stepping
4gb (2x2gb) PC8500 Patriot viper RAM
old 250gb IDE hard drive from his old computer
old 52x IDE CD ROM drive from his old computer
Thermaltake CL-p0024 tower (same as mine except 92mm antec fan)
Antec three hundred case (same as mine)
650watt Antec 80plus power supply
896mb PNY GTX260 216SP 55nm GPU
23in LG 1920x1080P LCD Monitor
All cables are hidden at the back of the case to ensure good airflow and I apply a thin layer of AS5...
I started with 2.83ghz stock, installed windows xp 64 bit and all software, then proceed with 400x8.5. Here are my settings below:
CPU Vcore = 1.25v
CPU VTT = 1.2v
CPU PLL = 1.5v
NB MCH = 1.3v
RAM = 2.1v 5-5-5-15 @ 1066mhz
So the next step I did is open OCCT and start the regular test. I notice the idling temperature were 43/40/38/39C, and then jump all the way to 67/65/66/66C at 100% CPU usage. When I tried linpack it will just jump all the way to 80C+ and then the test stopped... Is that normal for quad core? Me and my friend both use the same cooler and same thermal paste except his antec fan spin at 2000RPM whereas mine is only at 1700RPM. I was hoping to get his Q9550 to 3.8-4.0ghz range, looks like it's not going to be easy.
Q9550 E0 stepping
CPU Vcore = 1.25v
CPU VTT = 1.2v
CPU PLL = 1.5v
NB MCH = 1.3v
