- May 22, 2011
- USA
- Thread Starter
- #21
Learn something new everyday, I did not even know of the EVBots existence, Thanks Jack!
No problem.
Jack, do you know if you can control the GPU with a Raspberry Pi like you can the EPOWER?
That's a great question. I did a little search and found this.
If you are a first timer to the extreme world, you might not have lot of experience about what hardware mods to do on your card, or what traces you need to cut to disable overtemperature/overcurrent protections.
No worries, you can use KPE just as it is for the ALL your LN2 sessions. You only need voltage control tools, which could be either EVBOT, SW tool such as classified voltage controller, or even fancy Raspberry Pi. As already mentioned, 980 Ti KINGPIN is designed so there are no hardware modifications or soldering required to reach maximum clocks with your GPU and VMEM, just like all other Kingpin edition cards.
Source
