- Jun 2, 2011
- Caldwell NJ
Ugh, yes. Hope you can help. I am dusting off my 4790K in the hopes of getting some more life out of it - problem is my case - Coolermaser 690 II too small for a large air cooler ( big Noctua or the dark rock) - current set up on gigaby z97 3UDH is using an old hyper 212 - its about 151mm tall and has little clearance - I can get to 44ghz reliably and likely 45 if I would do more than tweak the voltage. a Corsair AIO seems an good option but will be a difficult install. Suggestions would be welcome - I am not sure whether to shoehorn the h100i in or try something like the DeepRock TF (that the one with horizontal fans) Thanks for any advice.
