Idle temps won't be off more than a few, if any, anyways. Load temps are what matter. If you're using offset voltages, which there's no reason not to for daily use, you idle at 1600 MHz and ~1.0v whether stock or oc'd
Seem decently stable. Ran Prime for a good 20-30 min without any BSOD's or windows errors...need further testing obviously...but no crashes and ran BF3 for a solid 2 hours with no crashes. currently @1.27V 4.5GHz. Ambient temps (ill switch to Metric) are 23.8'C
Well 3 minutes of testing will not be the high temperature. You have a water cooler so give it at least 30 minutes. That said, thy wont be much more, and temps are fine!
