Hmm.. http://www.xbitlabs.com/news/graphi...Recall_GeForce_600_Series_Graphics_Cards.html
I'm NOT posting that so it can be spread far and wide. The original source is dubious at best. No way it's making our front page without corroboration, but since this is the info thread I'm posting just for those that like all info on the series. Color me skeptical.
Note the current restrictions on what you can step up to. Only the base model 670 and 680 are eligible for stepping up to ATM. So if you get a base 680, you can't step it up to a SC or FTW. Hope that changes soon...It depends on the card you choose. You get full credit for the card you purchased towards another card. For example:
You paid $400 for a 670, but will upgrade to a $500 680. It costs you $100.
All this information can be found on their website as well.
Well, the FTW has 4GB, that's more of what I was getting at. I was thinking of maybe getting a a base 680, then stepping up to a Classified whenever they come out, but I'm guessing demand for the Classified will probably be high enough for a while that you won't be able to step up to it.I certainly wouldnt step up to a overclocked version of the same card...when you can hit those clocks yourself, free, in minutes. Regardless thats good information to know in case others were thinking that way...
Mate i got the 670 . if its a choice between a 7970 or 680 i would go 7970. But with the gigabyte windforce 670 i got ( which has a reference 680 PCB) it kind of made it a a serious choice between a reference 7970 and 670. ( i wouldnt have got any of the other 670's with the stunted PCB) The reason i went with the 670 is that is has a nice aftermarket cooler on it. That with tide me over until i get to watercool it ( when i can just slap on a 680 waterblock.) If you can get a gigabyte windforce 670 i would say its a seriously hard choice between that and a 7970. I would say on water the 7970 will probs have the edge as it could probs get higher clocks. But we'll seeLet me know Xander: I hesitate between a 680 stock cooling and a 7970 full WB.
Gotcha, thanks. I'm primarily making my next rig for Flight Simulator and XPlane, and XPlane 10 can burn through 2GB VRAM pretty quick, even at 1900x1200. A guy on the X-plane.org forums has a 680 2GB and he said he was occasionally hampered by the VRAM. Might go with a 4GB 670...LoneWolf121188, FYI I gamed for a while last night at 5760x1080 (photo) on a single GTX670 and it was fine on Metro2033. I turned detail down to "normal", dropped MSAA x4 to AAA and dropped AF x16 to AF x4. I suppose if I had looked for a difference I'd have noticed one, but it those changes kept graphics looking good and the gameplay was smooth as butter.
EDIT - For clarity, that's an ASUS GTX670 DirectCU II TOP, with 2GB of memory. It ran high resolution just fine. I'm not sure if the processing power hampered it at higher detail or if it was memory size. I'm guessing processing power, but don't really have any way of testing that without a 3GB card here to test.
Am I the only one that doesn't like the look of that Gigabyte cooler? No offense xander, just not my taste. Something about it is just creepy to me...like the fans ripped the skin off and exposed the skeleton inside. (Everyone else is thinking: )
