That cooler SHOULD cool better, but even when F@H with my 680 at 1200 boost (1.21v) I dont break 60C (21C ambient) with the fan at 55%. Weird.
Furmark... bleh... missed that. Shouldnt be used as at least Fermi intentionally throttled when using that application. Loop Heaven or 3d11 or something. A more realistic load.
You cant control voltage though... You talking the Power Threshold?
How can you raise volts? That option is off when I click on it...(Giga reference). I can move the slider but nothing changes.
Volts are locked at 1.175v, max...
Power target seems to have some dubious results when maxing it. I've seen guys with 670s that get better oc's out of lower power targets.
You should really check the max freq from an AB or Precision graph, cause these cards tend to boost higher than the supposed stock "boost". For example, most GB Windforce 670s would boost from 980 to 1150-75 supposedly, but show an extra 150mhz in the graphs. And to that you should add your +x core offset.
It's rather odd, but I've read stories accross different sites and that seems to give better results with your card.
It's all in the temps you get, too heavy a load like Furmark and you won't see the real oc potential the card has.
Also, you should tweak with memory once you figure your highest stable core clock.
Once you find the point where you get artifacts or crashes you lower to your last stable core offset.
You then raise mem speeds and check with 3dm11, when you get to the point where your score won't go up without artifacting it's time to lower the core to see if you get some extra mhz ram-wise. Bandwidth never hurts
See which gives you the better scores, highest core with not so fast ram, or slightly faster ram with not maxed out core.
