- Mar 7, 2008
I keep saying to myself I should get some high speed ram for benching, and in particular, get some in ready for Zen 2. I look at 4000 rated kits, and 2x8GB HyperX RGB is from around £170 or so, which is about the best I've seen it. Then I see Gigabyte 2x8GB 2666 for £60 on sale, or about 1/3 the cost. Well, Zen 2 can still have my existing B-die kit and I will have to do it manually.
High end benching aside, is there a sweet spot? I just ordered a kit of 2x8GB Ripjaws V 3200 for £77. I hope it is the same kit I have in my original Skylake build, as it is dual rank which really helps the performance in compute. Timings and description as a 2015 kit fits exactly. Can't get it easily any other way. Kits with 4GB modules are much worse per GB.
As a further thought, has anyone tried the Ryzen timing calculator? It's on my to do list of things to try some time... just wondering if it delivers.
