Allright first I want to clarify that im pretty new to OCing and hopefully i can get some help. I know some of the basics. Let me tell you the specs and components of my PC first.
CPU: intel q9550
MoBo: Asus Maximus II Formula
memory: 4g Corsair xms DDR2 800
Video card: 2x ATI radeon 4850 512mb
Cooling: 2 case fans and for CPU cooling I have a Thermaltake MaxOrb CPU Cooling Fan(95 mm fan) and heatsink
I've just started to research about overclocking, Ive tried it before but was confused with all of the computer gibberish and kind of gave up for a bit. But I want some more performance out of my comp so I decided to get more serious about it. With my mobo it lets me select the speed of a faster processor, theres 4 options the stock speed and then 3 higher. All you do is select one and it adjusts all the other settings for you. I selected each one and checked out how much faster my core speed was. I decided to go with the fastest one and my computer hasnt had any problems with stability at that setting. Not to drift off topic here but i have a question about the multiplier. When i run cpuz it shows my clock speed along with the multiplier, it shows a multiplier of 6 but will go up to an 8.5. I was hoping someone could explain this too me. Ok back too the main discussion. I researched it a bit and I found out i can get better performance by just manually doing the overclock instead of the automatic one. Not surprised. So i started researching a bit on how to do it manually an found this site. Read the OC guide a bit and watched some videos on youtube. I went into my my BIOS and changed the CPU level up to manual, allowing me to manually adjust my FSB speed. With that auto overclock it was at 412 MHz. I decided to kick it up a notch and with increments of 10 MHz I got it to 460 MHz then foolishly decided to leap to 500 lol. Well i booted i could tell it wasnt working correctly. I got a screen that said overclocking failed then i lowered it to 475 and same thing. So basically keeping it at 460 atm. All of the other settings in that menu are on auto, i dont want to mess with them because i still dont understand what some of them are. When I raise my FSB it auto adjusts my DRAM frequency.
I just want some help with adjusting my settings in accordance with my FSB frequency and my DRAM frequency. I want to reach the highest possible performance level i can for what i have. I also want to know how to test if my overclock is safe and my system is stable. Thx for reading, sorry about how sloppy this thread is its 2 am right now and im kinda tired. Will appreciate any feedback
CPU: intel q9550
