lclark2074 said:are you putting a screen filter in acumulator
Borisw37 said:AMAZING !!!!
A couple questions:
1) Does the condenser has differnt size tubing on Intake and Exhaust. Intake should be large, exhaust small, right?
2) What is the power consumption of that compressor?
3) What is the approximate cost of this project.
lclark2074 said:whairs the epoxy going
that system rox man.. good job keep it coming.
Wow, you have inspired me once again! When are you going to be posting the final amount spent on each part and do you have any problems with the compressor being located at its current location, does it get enough air flow, etc? Two phase change systems completey enclosed within the case, YOU THE MAN
I allways wondered how you guys lapped the evapos base after solder. It must be a pain in the Azz!
nunez1980 said:well found the link, this guide is for doing the whole thing, which I will do soon to my lovely p4 link
I really recomend this to any one that has a amd chip or p4 without the heat spreader, using whatever cooling they are using, I even try an old chip, and I try to crack the core and it was impossible, no matter the pressure used, and tested the epoxy and it was non-conductive you you can use anywhere on the chip, I have to try did cause my block was 1.5", and I couldn't put them where the original pads were located, so they are touching the bridges
