Eradicator said:
Nunez,
How is that flexible tubing working out and how much oil do you run in your system?
hi there, well the tubing is working good, actually is the best thing I have ever used
and if you read about tubing, you know I have try many different types, and this one is the best, cause if you want an angle, you can have it, any way you want, its just a little hard cause its metal, but compare to the others is like butter
also this one is easy to made, and if you need to change the length thats no problem,while the other you can't change the length, and with the others I couldn't do the correct twist that I need, only the charging hose comes close but it will leak at the connection, since they hold with a rubber ring, which will leak when you freeze it,
well if you have any more question, just let me know
sniper thanks for the compliment, and come on start think about, you soon will see with some precation, is a piece of cake
by the way, I almost forgot to mention about power,
on this pic, you can see the black power switch, above the floppy drive, this I got from radio shack, and when its switch on, it give power to the compressor and the 115v fan connected with the condenser, and when it reaches the target temperature, you can power on the pc,
well, I hope everyone is alright, and good night
