- Jan 4, 2009
- Brandon Mississippi
- Thread Starter
- #21
Sounds like the card now ya before you deside use driver cleaner first then put on your new drivers for the new card ....
I would add NB & SB volts too to rule that out if that stableizes it then put the SB back where you had it and try again to pin it down ....
Strange it works with 8800 gt & not the 4850 thiskinda points at the card
Yeah, i'll try and see if i can get my friend to bring his 8800 over, and i'll drop it in there and see if it works with that.
I did try bringing the NB and SB up, and it didn't do anything. That was one of the first things that i tried before i came here. All it did was make them run hotter lol
Yup both use similar power. NB & SB increase i think as well to help rule it out. Not too much just 1-2 up from where it is should do the trick.
Maybe there was a power spike and might of wreaked part of the PSU and maybe some other components? <- last resort thinking
We have pretty clean power here, so it'd be a one in a million chance of that happening, but it's certainly possible... If that had happened, wouldn't i'd see affects with my old card though?
