- Aug 13, 2010
Here is my ram:
http://www.crucial.com/usa/en/blt4k4g3d1608et3lx0
Quick question:
Since I OC'd my CPU and my base clock is now higher I can't use the XMP profile. So my memory is running at 8-8-8-24 1900mhz and I up'd the voltage to 1.64v.
My question is.. being a low voltage memory requiring 1.35v should I have them at 1.64v or will I damage them? Or do they only pull what they need UP to 1.64v? I only put 1.64v because I was following an over clocking tutorial that recommended to do so. To be perfectly honest I don't care if the memory is even overclocked, I suppose I could play with my bclck and multiplier to get just the CPU oc'd and put the memory back to XMP?
What do you all suggest? Also I've heard tightening timmings is more advantageous than overclocking when it comes to memory. Is this true? I'll have to research more on timings and how they work..
In my current config i have not bsod yet, I've passed 10 passes of intel burn test on high and I'm about to do memtest86, I just don't want to hurt the ram.
My whole system is:
Gigabyte GA-X58A-UD3R
Intel Core i7-930 currently @ 3.8ghz
Mushkin 1TB SSD
16GB Crucial Ballistix Tactical LP ram
Gigabyte Nvdia GTX-970 G1
Thermalright U120eXtreme CPU cooler push/pull
Antex 900 case
EVGA Super Nova 850 G2 80+ PSU
the bclk is current 190mhz
ram multiplier is 10
cpu mulitplier is 20
dram 1.64v
ioh 1.3v
vcore 1.3v
uncore ratio 20
qpi/vtt 1.375v
Windows 10
Thank you
Quick question:
My whole system is:
Mushkin 1TB SSD
Antex 900 case
dram 1.64v
ioh 1.3v
vcore 1.3v
uncore ratio 20
qpi/vtt 1.375v
Windows 10
Thank you
