Hello,
I am opening this thread to log my attempt to OC my RIG, and check for solutions.
I am running now at 4.65 GHz at 1.344V. I am checking stability and temps with OCCT: OCCT. The reason I use OCCT is because it can stop the test based on temps. For now I am using just the FSB to push. Keeping the RAM, NB and HT at or below 1866, 2400 , 2400.
The problem is that in a 4 hour check the package temp reached 61º (CPU 65ºC). Ambient temp should be between 18º and 22º C. I was expecting much more cooling from D15. RGone reached 4.6 GHZ at 1.45V with a low cooler and the package temp was 59º.
Later I will post all the settings. Questions:
1) Can the D15 be defective, and thus I am getting high tempos? I could have mounted something wrong? Pea method Noctua thermal compound.
2) 62º is the absolute max temp for 8350, or it is ok to spike at or little above? At some point I must set the rig for 24/7 usage.
In case someone stops here looking for OC information I highly recommend: http://www.overclockers.com/forums/...s-gt-gt-Using-the-AMD-FX-Bulldozer-Piledriver
