- May 5, 2014
- Courtenay BC Canada
Hi folks...frequent a few other Forums but new to this Site....I like it as it seems there is a very active WC'ing Enthusiast Gang here
I should mention built several Ris in the past but this one is first go at a Custom Loop.
So...been running this Loop for a few weeks now...close to that anyhow, so just want your thoughts on my Temps.....okay..?...or is my OCD once again taking hold
First the Loop:
Pump: D5 Vario / Res combo - pump running at a tad over #2
XSPC EX 360 Rad up top - push / pull Corsair SP Series exhaust
XSPC EX 360 Rad below - push / pull Noctua NF F Series Intake
2 x 780Ti w EK Full Blocks
3930K w EK Supremacy Copper / Acetol
Been playing around with my CPU OC a bit, gaming etc and thse are my Temps:
Ambient Room Temp around 22c
CPU: 101 Bclk * 48 = 4.85 Ghz w 16GB Corsair Doms @ 1880 Mhz 9-10-9-27 2T
EDIT: Forgot to mention Offset OC'ing - vcore under full load 1.392v - 1.401v
GPU's: +145 Mhz Core / +260 Mhz Memory = Run at 1244 Mhz gaming
CPU under full load LinX 15 Cycles - Core Temp: Max Temps 71c - 65c- 62c - 69c - 60c - 68c
All idle around 27c - 32c
I believe with my previous Swiftech H320 push / pull just cooling my CPU the Temp were about +6c compared to present Temps.
Playing BF4 I get a Max CPU Temp of 64c with all the other Cores around 55c - 58c
GPU's Peak Looping Heaven or a 60 min session of BF4 stabilize at 45c - 48c (both seem to idle at whatever the room temp is)
All Fans on the Rads are running around 80% - so there 1450 RPM Fans, would think they're running around 1100 - 1200 RPM.
So, these Temps seem alright?
Couple of things I'm considering:
1. I didnt install the 2011 Socket Jet Plate on the CPU EK Block (left the installed Jet Plat on, as instructions stated "optional"), would installing this reduce temps much on the CPU?
2. Adding a 240mm Rad to the Loop down below.....if I did this I think I would have 1 set of Fans on both Rads down below (not push / pull)
3. Swapping out the top 360mm Rad for a full Quad 120mm Rad up top.(and still adding 240mm Rad below)
Anyhow, for you WC Enthusiasts your opinions on my Temps is much appreciated, sorry, fairly new to the Wet World so still monitoring / questioning some basic stuff I know.
First the Loop:
