- Jan 1, 2008
- Colorado Springs, CO
That's exactly what I was looking for when I was building my 955BE system. Just happened the snipers were on sale on new egg
Having all 4 slots full and 16Gig of ram can be hard for a PII IMC to handle. We can look at that later. Thanks for the sig by the way that helps. I also looked into your case, those 200mm fans don't really move a lot of air. You can do a quick check to see if you need more air just by taking the side door off the case and then testing with Prime95. If you get a big drop in temps you know you need more air. As for the thermal paste, any decent paste is fine. Arctic silver 5 is OK but dated any more. I like Phobya HE grease. But like I said as long as it's decent thiere is only a few degrees difference.
Some progress done.
Removing a side from my case, resulted lower temperature of CPU while Stress Test on PM95 goes on. Remember, it was 67c, and now with side removed is 60c. I guess that means I need more air inside my rig, dont have a clue how to make it done tho, alot of fans inside already.
Disabled CPU Q FAN control in BIOS, apparently this was holding up fan reaching maximum speed (which is 2000 RPM for CM Hyper 212), this resulted steady 2000 RPM constantly, over 1500 RPM I had before with Q FAN enabled, so I/We gained 500 RPM+ in my Rig.
More RPM from fan with side removed, resulted steady 58c while CPU is under Stress Test. It is almost 10c less tempereature of CPU core while on stress (compared to temperature I had when started this topic), which is, i suppose, good thing.
Maybe with better paste it will be desired 55c after all.
Cool 'n' Quiet option is still enabled in BIOS, not sure should i mess with that?
Regards
Axar
So far I personally like IC Diamond paste, but that's just me. For the fans, you may need to upgrade the case fans themselves, or, optimize the air flow through the case. If you have fans in an odd inlet/outlet config it could be less than optimal due to the airflow not making good channels
1.) > Most of the time "side-fans" can create turbulence around the air cooler on the cpu and cause the cpu cooler to be less efficient because it cannot get good air to push thru the cooler fins. Care is a must that this does not happen as it is sometimes hard to diagnose.1.) > Will install side fan and new paste today or tommorow, best I can buy here, and will report here with results.
2.) > Short question, messing with NB, will it bring some noticable change, like increase of FPS in games, beacuse if not, maybe best solution for me is not to touch it.
Cheers
2.) > Within reason running a faster CPU_NB speed is usually a plus in games on AMD systems. However it is "most" noticeable with fast ram speeds. Slower ram speeds do not "show" so much increase even though there may be an incease; it is just 'harder' to see the bonus.
RGone...ster.
AS 5 and Arctic Cooling MX2/MX4 are widely considered the best value in thermal pastes. Excellent performance and reasonably priced.
