QuietIce
Disabled
- May 7, 2006
- Anywhere but there
- Thread Starter
- #41
Thanks!Damn glue bottle slipped out of my hands and fell all on this poor old thread.
You should always set all RAM sticks the same.i was just wondering, you say use just 2 sticks of ram when oc'ing, can i put the other 2 sticks back in when finished and do i set them to allow oc in bios or not??
"Increase the clock 5 MHz and reboot to Windows. Run P95 for a couple of minutes and, if it runs OK, reboot and enter BIOS."
lol
Who does that?
dumb O.C guides.
Easier to read a few setting of people who have the same chip and go for it with a decent first go.
or put in the the v.core you want then go for a high overclcok and back it down till you can boot into windows. once in windows run prime95 or left4dead(i find steam games will crash if not stable), it all just about ****ing around with some settings till stable and getting to know what your chip will handle.
I can usually work out what my chip is capable of with in a few days. its a good thing I never bothered to read these guides, I just search forums and see others results if I get stuck.
better then all this **** arsing around of 5 hertz steps.
Nothing wrong with that IF you know what you're doing ...Easier to read a few setting of people who have the same chip and go for it with a decent first go.
Most K8 OC's are slightly lower with four sticks compared to two sticks. The reason for only using two sticks for OC'ing (in this thread) is to test the limits of the CPU and RAM by itself. IMO, you should performance test your system with two sticks then add the other two sticks and test again. It depends on the app you're using but sometimes the extra RAM doesn't really help, especially if your CPU speed has to be lowered to accommodate four sticks ...
ok i have and amd prcoessor....i remeber when i just changed the multiplier freom 14 to 15 in the bios when i tunred on my computer screen was blank......does AMD cool n quiet have to be off to overclock was tht the reason my screen was blank?
I don't know if that's the reason your screen was blank but that's the whole point of overclocking this way - you don't know. Narrowing down the variables is what it's all about so you can concentrate on the overclock and not play guessing games about what's wrong. By turning off everything not needed and setting the critical variables manually in BIOS you limit what the BIOS and computer can do to your system while you're testing the overclock. That way if something does go wrong, like a blank screen or BSOD, you have a better idea of where to look for the problem.Manual Entry and BIOS
While in the BIOS also turn off CoolnQuiet (CnQ) and any CPU or system fan regulators. CnQ is found in a number of places in BIOS and allows the BIOS to change the CPU multiplier and vCore depending on the CPU load. It might be good for future use after over-clocking but not during. CPU and system fan regulators aren't a bad thing either, but it's better to keep the components as cool as possible right now so turn them off and turn them on afterwords if desired.
The HT Link being turned down that low will probably effect video performance (especially with SLI). With that board (the ASUS '32' boards are excellent OC'ers!) at a 215 MHz clock you can probably run the HT Link at 5x (1075 MHz) without a problem. If that effects your CPU overclock then I'd run some 3dMark tests to find out where the best settings are. You might be better off lowering your CPU OC a little to gain a lot of HT Link speed or you might be better off where you are. Until you run the tests you'll never know ...Will the FSB x (HT) being lowered affect performance? I am new to the athlon 64 OC
well trents ive tried everything to overclock my asrock n68 even tho it has untied overclock technology whenever i overclock it never works, pc is on but screen is off, so i have to do all the cmos thing....question is i got a software asrock oc tuner wich came with my motherboard can i use that you guys think its safe?
