Hello everyone, I am at 3.4 currently and I am having a really hard time making it 100% stable, but I am close. Take a look at what I have I hope someone can help me see why I am unable to scale any higher.
3.4 X 9 377 Rated FSB of 1510
OS - Windows Vista 64bit Ultimate
Ram - 4GB Patriot PC2-6400 PDC22G6400LLK
Mobo - Asus P5N32-E SLI PLUS
Case - Antec 900
I have left the memory stock and only played with the FSB at a 1:1 ratio unlinked at 4-4-4-12.
I am able to prime95 small FFT's on both cores ver. 25.6 for about 1hr and 35min until 1 core stops with an error message that reads something like ex. "FATAL ERROR: Final Result was 33cd45, should be 43c243" and the other core keeps going normally, it used to be a rounding error "Rounding was 0.5 expected less then 0.4" but that stopped after I bumped the votage. I also have not checked the Blend or large FTT yet.
My voltages are pretty crazy right now but temps are fine with a max CPU temp of 55-56c on both cores at load.
Voltages:
Vcore: Set 1.536 = 1.5-1.52 in everest (1.52 in bios)
NB: Set 1.5 (1.52 in bios)
1.2 HTT: set 1.45 (1.50 i bios)
SB: set 1.5 (1.52 in bios)
Cpu VTT: 1.45 (1.50 in bios)
temps : Mobo = 31-34c
So im not quite sure what Im doing wrong, maybe my cpu has reached its max and cant scale anymore and maybe i need to work on the memory a little.
Any help would be great!! Thanks so much
Case - Antec 900
Voltages:
