- Dec 27, 2008
A client whose computer I am servicing does something I have never seen.
As soon as the last character of her Windows password is typed in the Windows 10 login screen it loads the Windows desktop. You don't have to hit the Enter key or click on anything. This isn't a setting is it? Can't find any info on the net about it.
This computer was upgraded from Windows 7 to Windows 10 several weeks ago. Several days ago it began to exhibit erratic behavior. I restarted it and it did a disk check and repaired some stuff but his login issue persists.
Right now I'm scanning for malware and after that I will do another chkdsk /f /r and sfc /scannow scan from command prompt.
Any ideas?
Any ideas?
