- Feb 2, 2001
- Delray Beach FL
This started in another thread but needs a new subject. The problem is how to attach two burners and one drive so that the burners are on different IDE channels. The problem is that the drive sits in the drive cage at the bottom of the case while the burners are at the top of the case.
So, hooking up one cable to stretch from the MB to the HD to the burner doesn't work unless the cable is flipped over and the motherboard connector is used for the burner, the middle connector is used for the drive, and the remaining connector plugs into the motherboard. That works physically but won't boot. Either I mucked something else up or the cable can't be flipped. Should that have worked?
Is there a more appropriate cable? It's a mid-tower case.
