THE PROBLEM: Well now i've done it. Brand new system, just a couple days old. Tried to OC it to 4ghz but prime95 crashed within seconds regardless of how i configured the settings. so i backed it down to 3.8GHz. booted up fine, ran prime95 for at least 15 minutes but temps were getting high, around upper 80s. Computer crashed and shut down, when i attempted to restart i got no response.
WHAT I'VE TRIED: unplugged power cord for a few mins and tried again, still no response from either the case power button or the mb power button. sometimes i get a fraction of a second of leds, sometimes i don't. pushed the "clear cmos" button on the mb, and also tried the process to reset the bios with a jumper. also no effect. swapped out the power supply with a known working power supply, no change. took out 2 sticks of ram, no change. tried with one of the other ram sticks instead, no change.
SYSTEM SPECS
Core i7 920 D0 stepping
Xigmatek Dark Knight HS & Fan
ASRock X58 Extreme
PC Power & Cooling Silencer 750 quad
OCZ Platinum 6GB kit DDR3 1600MHz cas 7 OCZ3P1600LV6GK
80 GB Intel X-25M 2nd gen
i'm at a loss. now i have no screenshots as my system wont boot or even post to the bios. but the settings i was using to the best of my memory are as follows.
cpu 200*19
vcore 1.325
uncore 3200mhz
dram 800mhz (1600)
ram timings 7-7-7-18
i'm just so disappointed, my previous pc was an old amd 3200+, apparently an oc'ing beast, but when i tried to oc it i had similar results, i had to "hot flash" the bios chip to revive the system. now my i7 system is failing to oc. everyone else in the known universe just tries diff settings till they find something stable... when i test my limits i end up with doorstops.
any help is greatly appreciated.
SYSTEM SPECS
ASRock X58 Extreme
cpu 200*19
vcore 1.325
uncore 3200mhz
dram 800mhz (1600)
