- Dec 3, 2002
- Purdue University
- Thread Starter
- #21
if i do try that and turn it on wont it just fry. It was a clean break for the most part except for like 2 tiny wires that frayed out a little bit.
apu318 said:You could try tossing it in the oven with theram chip RIGHT over where it broke off.. the solder should melt and then let it cool down and harden. I've heard of people doing this but I don't know if its actually ever worked. I'd imageing that everything else soldered on would fall out.
corruption said:Just think about what you said.....if the solder melts under the ram chip, then the solder on the rest of the board will too. All your surface mount components will slide out of place or fall off. If you wanted to honestly try to repair this (I'd say it's hopless though...especially if there are "wires" poking out of the board.) you'll need solder paste and a hot air solder gun. Since it's toast, I'd say go for it, but expect it to remain "fubar'd."
