I have a gigabyte mobo!
Just getting started....wow.....
ddr620 with ras-cas3 timing! It did fail superPI instantly but I believe it may be my cpus fault, I did get superPI to pass at 300x8 which is a very good sign indeed! I am gonna see if 3dmark will run at 310x8, if not ill relax timing to ras-cas4 and try to get even higher to make up for the hit. I will also try 285-290 with 9x multi but the cpu will be pushed very far to its limit, might not be too stable even in 3dmark. 300x8 is a VERY good starting point, gonna see if I can get either cpu and/or ram higher. Wow, can I say wow again? 2x256mb is soooooooo much easier on the ondie controller its unreal!
