- Oct 29, 2011
- California
Hi. I'm new to this forum and I am VERY new into computers. I just recently had an interest in them. I play PC games and I use Photoshop extensively, so I thought that building a PC that was perfect for my needs was a great decision.
I have never put together a PC before, and after a week or two of research, I learned how computer parts together and what parts I wanted. I got all of my parts together, but the total was just a little too much for my budget. I wanted a total of $800 or less, but it didn't turn out that way... And I also want a build that can run BF3 with at least medium settings (high would be very nice)
I hope I learn a lot from this forum and I hope to be able to contribute as much I can.
If there is anything batter than the part I am thinking about using, or any general tips, then please post them below. Also, I have a few questions, so please answer them as best as you can. THANK YOU!
Here's my build:
1) ASUS M4A87TD EVO AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard $103
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131647\
I don't know if this is the best MOBO for my system, but if there is a better one, then let me know. I am willing to spend up to $130.
2) AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor $120
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
I really want the X6 1055T, but I don't know if there are any main differences.
3) EVGA 01G-P3-1556-KR GeForce GTX 550 Ti (Fermi) FPB 1GB 192-bit GDDR5 PCI Express 2.0 x16 $140
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130625
I heard that this was the best version of this video card, I'm not sure though...
4) CORSAIR Vengeance 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) $50
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233164
I wasn't sure whether to get DDR3 2000 or 1600. If there's no difference, then Ill get 1600. I heard that the 2000 has better overclocking...
5) Western Digital Caviar Blue WD3200AAKX 320GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive $75
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136770
I don't want a high capacity, but this HD only has 16MB cache. If there is a better one let me know.
6) OCZ ModXStream Pro 600W Modular High Performance Power Supply $75
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017
I'm not sure if this is the best power supply, or even if I need this much power...
7) ASUS 24X DVD Burner - Bulk 24X $20
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
This is the best one on NewEgg. As far as I know...
8) TRITTON AX 120 Performance Gaming Headset for Xbox 360 $60
http://www.newegg.com/Product/Product.aspx?Item=N82E16874704005
Compatible with both Xbox and PC, so no changing this.
9) RAZER Arctosa Black 104 Normal Keys USB Wired Standard Gaming Keyboard $40
http://www.newegg.com/Product/Product.aspx?Item=N82E16823114009
This is for budget. If I lower the total, I'll switch to the Sidewinder X4: http://www.newegg.com/Product/Product.aspx?Item=N82E16823109191
10) RAZER DeathAdder Precision Optical Gaming Mouse - 3.5G Infrared Sensor $50
http://www.newegg.com/Product/Product.aspx?Item=N82E16826153055
No changing my mind, I want this baby.
11) Rosewill DESTROYER Black Gaming ATX Mid Tower Computer Case $50
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147144
I want a case that's under $50, but if theres is a really awesome case within $100, I'll look into it.
Personally, I like the aesthetics of this case. I heard the CHALLENGER is a better case though...
12) Kensington 56001 Optics-Enhancing Mouse Pad - Black $5
http://www.newegg.com/Product/Product.aspx?Item=N82E16826999006
If I'm able to lower the total, then please suggest an okay gaming pad. Nothing too crazy, maybe under $20 will do.
Here's my build:
