- Feb 15, 2003
- Mesa, Arizona
.. well.. uhh, yeah... ummmmm
mines better
mines better
zeimbo said:ive seen a dual xeon sli board that has onboard raid 10 i believe and ive heard that there is a quad opteron board with sli and scsi as well. whats the retail on those badboys?
zeimbo said:ill have to teach you how to sleeve one of these days
Jod said:Oh my, single most frustrating thing I had to do for my pc, lol! Of course it didn't help that I was missing a good amount of the "right tools." I could have REALLY used a hot knife, extra hs tubing, and some more zip ties.
zeimbo said:but it doesnt glow under teh uv light
RedDragonXXX said:BTW...Jod good job on that PSU
GáTê©rÀ$Hë® said:sO aDjusTing tHe pOt woUldn'T voiD thE waRrantY?
i hAve the saMe PSU but With muCh mucH loWer voltAge on The +12 (11.71 idle - 11.64 load)
wAs it tRickY to Open up the PSU cAsing?
Wolf reccomendEd this PSU long long time aGo, n i guess i Got the early rev.
wOulD this Be the rEason a US$4000+ worth of rIg bloWing up?
hehe
http://www.ocforums.com/showthread.php?t=444834
dominick32 said:To top it all off, the damn PSU is making loud squeeling noises when the video card is under full load. I just dont know what to do with this PSU situation anymore. I am getting fed up.
do u know if this can be done on my psu bc i realy dont want to buy a new one?dominick32 said:**UPDATE**
<---------Yes, thats a smile on my face.
It turns out that OK Wolf was right about some of the original units being underadjusted from the factory. There is one adjustment under the hood on this bad boy. Silverstone states that this single adjustment increases the 12volt and 5volt simultaneously. Here it is:
I slowly adjusted it, rebooted the PC, adjusted it, rebooted the PC again until I found a decent voltage. Initially it let me adjust the 12 volt rail all the way up to 12.40 @ idle. That was way too high for me.
The way my voltages sit right now are just about perfect:
Load readings were taken with one instance of Prime95 torture test, one instance of CPU Burn-in and one DRIBBLLERR..lol for the video card.
12 = 12.06 idle, 12.01 load
5 = 5.03 idle, 5.03 load
3.3 = 3.28 idle, 3.28 load
For some reason, they only built this PSU with one adjustable pot that only allows adjustments on 12v and 5v. But I am not worried about my 3.3 anyway because it doesnt even flinch during load.
Well, my day is a little better now.
Hope this helps others considering the Zeus 560 Watt 38Amper in the future to figure out low voltage problems. The rep from silverstone said that all of the newer revisions do not have this problem.
Dom
DeepScience said:What happened with the squeeling? Did that go away with the voltage adjusted?
EvilT said:do u know if this can be done on my psu bc i realy dont want to buy a new one?
Oooops Guilty as chargedI dont know how happy theyre gonna be about multiple members calling them up asking for warranty breaks though
Supershanks said:Oooops Guilty as charged
Got mine the other week Which has best Beefy PSU Wolf kindly pointed out the fix. Very pleased with unit. Vrzone.com Article: Silverstone Zeus ST56ZF is a good review - probably less contentious than Toms Hardware
Thanks a lot for posting the pics.
Yes was very impressed by their prompt reply 2 my Email & practical resolution. Nice to see a Case maker make decent PSUsThey seem to be playing along with an honest corporate role.
