Waaaay back in 2011 I made this thread http://www.overclockers.com/forums/...First-Build-please-help?p=7000761#post7000761 and was greatly helped by the community here.
When i made that thread I expected to upgrade some parts in a year or two but honestly I underestimated just how huge an upgrade I'd experience from the prebuilt computers i was used to. To the extent even to this day I don't feel a pressing need to upgrade my build. Alas however time and use have taken their toll and signs of failure are creeping in, the motherboard is losing functionality left and right (almost all its usb ports failed, it can no longer use a video card, its native graphics is getting iffy, and the occasional rare boot error that i think is it too since it happens very early), its hard drive is becoming unstable, and memory notices are cropping up here and there.
That said as far as i can tell the processor is just fine, the power supply has never blipped, cooling/case/oddball little stuff accounted for and in good shape. Additionally I have an unused copy of windows 7 pro.
MMO/RPGS are still pretty much the hardest thing its gonna run... tho i might have the bad habit of running several at once.
Details of prior build
MB ASROCK|Z68 EXTREME3 GEN3 1155 R
VGA HIS|H695QNT2G2M HD6950 2G R
PSU PC POWER| PPCMK2S750 750W RT (i know this is overkill i was planing to go dual card on graphics but that never happened)
CPU INTEL|CORE I5 2500K 3.3G 6M R
MEM 4Gx2|CORSAIR CMZ8GX3M2A1600C9
HD 500G|WD
I think all of this came up in the prior thread so more details are there.
I'm calling this a 1.5 build in spite of technically qualifying as another build because i'm on a pretty tight budget (about $600) and I don't really mind if performance doesn't improve much (from the old ones peak obviously its current state is kinda sad).
The most important things are the new motherboard and Hard Drive, new memory is probably a good idea (and i kinda wanna get away from the vengeance anywise i didn't care for the difficulties its size caused when i had to put things together), and the gpu itself may or may not be dead so if we can get a decent one in the budget I say go for it. cpu upgrade? if by some miracle there is enough money left over.
What I'm looking at
Mother Boards
ASRock ASRock Fatal1ty Gaming Fatal1ty Z97 Killer LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157501&ignorebbr=1 $109.99
or
ASRock Z97 Extreme4 LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157503 $114.99
Hard Drives
since i want 500-1tb of space an ssd is out of the question and don't think i'd do well with the manual steps needed for a small ssd/hdd dual drive setup to show its best.
I'm considering a hybrid drive since it would at least make a few key things quicker without me having to do alot of extra work.
Looking at this atm WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD10EZEX - OEM
http://www.newegg.com/Product/Product.aspx?Item=9SIA1N82KX4060&cm_re=sshd-_-22-236-339-_-Product $49.99
Memory
This is one of the few places i felt an actual need for an upgrade, but since i didn't care for the size of the prior build's vengeance I tried to avoid physically large ones.
Avexir Core Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Memory Kit Model AVD3U16001108G-2CW
http://www.newegg.com/Product/Product.aspx?Item=N82E16820011006 $49.99
or
G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9D-16GXM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231568 $67.99
or
G.SKILL Ares Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200) Desktop Memory Model F3-2400C11D-16GAB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231671 $61.99
GPU
Sadly i still stink at reading gpu specs so I'm certain any choice i make here will be sub-optimal.
assuming when you guys look this all over if the above choices are approved we've got around 300-400 to play with for gpu and cpu. That said any advice would be appreciated but sadly the budget can't get larger this time so I gotta stretch this as far as it'll go
(how would i test just how well my cpu is doing to know if there is a need to replace it that i haven't noticed?)
HD 500G|WD
What I'm looking at
Mother Boards
or
Hard Drives
Memory
or
or
GPU
